Ga door naar hoofdinhoud
iPod touch has no backlight
I have tried multiple lcds and all have the same problem where the backlight will not turn on. the same lcds work perfect on a different logic board. this logic board has water damage but works fine except it will not make the backlight work. what part on the board needs replaced? anyone have a schematic?
Is dit een goede vraag?
Score 2
2 opmerkingen
What iPod touch generation do you have ?
door
I have been working on the 1st generation 8gb and 16gb models so far. this one with the backlight problem is a 8gb
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
since some iPhones have the same problem, i would say that a coil is fried.
i found a picture on a gsm forum and the number 2 should be responsible for your problem.
some a replacing the fried part with parts from nokia bb5 series or SonyEricsson phones
Was dit antwoord nuttig?
Score 3
13 opmerkingen:
Hey thanks i think i will try that one then. im new to this tech stuff i am trying to train myself. i have some extra logic boards laying around i will attempt to solder in that piece. i have another one that works perfect now except the wifi doesn't work. can you switch out that top portion above the ribbon where the antenna is or are you just stuck at that point?
door
it's not easy to change the coil - no real chance with a soldering iron - i use a hot air rework station for those parts and even than it's not easy. is the wifi totally dead? don't ever think to change the communications part ;-)
door
when you turn on the unit in the settings it just says "no wifi"
well i wanted to attempt the coil but i don't know what to do now, i can't find any video on youtube about the change either.
door
ok i watched the air rework station and it looks like something i can do. how do you reinstall the coil? is it a solder?
door
The problem are the "glued" parts - this is whay those kind of repairs are not easy. soldering with hot air or infrared light are some times the only way to fix something, but there are many ways you could fry the logicboard
door
8 commentaren meer tonen
Sorry to bump a year old thread but the topics contained are relevant to my needs. I also have an Ipod touch 1st gen having the same issue, I have replaced the battery, the lcd, and the transformer highlighted in this tutorial however I am still having the same issue. There are no signs of water damage, or any destroyed components. Are there any I/O management ICs or controller chips I should try replacing? Any additional assistance would be much appreciated.
http://img686.imageshack.us/img686/9351/...
I found this coil to be the problem when I replaced the battery.
hi
Voeg je antwoord toe
chad franklin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 11,675
