Why doesn't LG Optimus G Pro screen turn on after I repaired it?
I just finished repairing my lense screen and after I assembled it my screen doesn't turn on? What can I do? Is it fixable?
Is dit een goede vraag?
Carefully inspect the LCD flex that connects to the board, or in this case I believe it connects to the charge port flex. Try applying a little pressure to it or check for any signs of laceration, if the flex is torn at all then the LCD is no longer good. I make the comment about the pressure because something similar happened with an LG G2 i fixed. No image on the LCD but when I would play with the flex the image would show.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 422
Did you double check your work? Did you make sure everything is properly connected? Have you tried the old screen to make sure you have a working phone? Why did you replace the screen? what happened to your phone before?
door oldturkey03
