Ga door naar hoofdinhoud
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Question mark when MacBook turn on?
When I turned on my MacBook, a question mark pop up without the apple logo or the spinning wheel?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Means no boot system found
Either your HD is trashed, or corrupt. You can boot from your install CD/DVD and run Tools->Disk Utility->Disk First Aid Tab->Repair Disk. (Do not do an install).
If you don't have/can't find your install disk you could try booting into single user mode and running a utility from the command line.
' Startup in single user mode ( hold down command-s after the boot boing ) you'll see white text on a black screen. When it stops loading/scrolling type /sbin/fsck'' press return.
  1. /sbin/fsck <- run this until until it is clean''' (no longer says "System modified) it will say volume appears okay.
  2. # type reboot press return
If the above fails boot in target disk (hold down the T key until you see the firewire symbol {looks like a stylized Y}
  • You can now use a dual USB or Firewire cable to connect your laptop to another computer, and backup your data.
  • Reformat and reinstall the OS - if that fails your HD is cooked.
Good Luck.
N.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
June zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,737
