Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Vragen Bekijk alle
swapping an 80g back plate with a 120g back plate
I replaced the hard drive in my 80g iPod Classic (Thin body) and when I tried to snap the case back together, holy cow, the hard drive is too thick! Will the back plate of a 120g or 160g iPod Classic work with this? Is it a thicker back plate? Will the metal clips be the same as on the original 80g back plate?
Thanks for all the help guys from all my previous problems. I love this site!!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Well according to the product's page, that shouldn't be a problem, all the back plates are interchangeable. Tell us what kind of drive you purchased, maybe you purchased one that's the wrong size, in which case you can get one that would fit here.
Was dit antwoord nuttig?
7 opmerkingen:
Well, the hard drive label says:
Toshiba
Disk Drive MK8010GAH
I think it would be fine if I just bought the fatter back. I don't really have the money to buy another hard drive right now. What do you think?
door
Do you have any way of returning the drive?
door
No, they won't let me return it. It's a good drive, refurbished and works just fine.
door
Try to assemble it again, pay careful attention to the teardown and see if you can do it.
door
No, didn't work. I even tried taking the foam off and it still won't go together. I guess I should just buy the back of a 120g.
door
2 commentaren meer tonen
Yeah the 120/160gb hard drives are dual platter which means they have two spinning disks instead of the one that the 80gb drive had. You need the thicker back plate.
Voeg je antwoord toe
Kimberly Jones zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 2,023
