Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
Vraag afgerond
LCD flex cable cut after power button replacement
Hi,
I was replacing the power button and all did well, I replaced the power button, unfortunately the connector was damaged so I did everything for nothing. After I took the power button off again i noticed that on the LCD flex the narrowest cable was split apart. The digitizer works, but the screen is black.
What is the function of the narrow cable?
Thanks in advance.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
That is the power for the backlight, it has two solder pads. If intact it can be soldered back, if split above the end, then you need to replace the entire front screen assembly for your iPhone 4.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks for the answer. Can the screen show anything, if it the backlight isn't connected?
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 110
