Ga door naar hoofdinhoud
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Vragen Bekijk alle
Vraag afgerond
removing the bezel off an iMac
I remove the glass, I remove the screw and ram, I remove the 12 Torx screws but I cannot separate the bezel from the imac. It is firmly attached no matter how hard I pull.
I can't see any other screws or etc. Anyone else have the same issue or know what could be keeping the bezel from being removed?
Thank you for your help.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I did it. I watched this video https://www.youtube.com/watch?v=yQi-3XYC...
And I just jiggled the top corner while i pulled and it came loose :)
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 354
