Ga door naar hoofdinhoud
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Vragen Bekijk alle
Vraag afgerond
Flickering LED
My LCD has developed a flicker to the backlight. My machine is not under warranty. From what I understand these machines do not have a separate inverter. I have seen conflicting information stating that I either need to replace the screen or the main board. Is there an easy way to tell which is bad?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The warranty ran out last month. I just ran the new EFI 1.4 update and the issue seems to have resolved for now. Hopefully this is the fix. Thanks for the quick answer.
Was dit antwoord nuttig?
Het nuttigste antwoord
The computer most definitely should be under warranty.
Check it here:
https://selfsolve.apple.com/GetWarranty....
It will be hard to tell which components are bad without actually disassembling the unit and testing separate parts.
If you really want to get to the bottom of it the apple store may be a great option to isolate the issue so you can attempt a self repair in the future if the device is out of warranty.
Hope this Helps!
-Varsity
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 949
