Ga door naar hoofdinhoud
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
56 Vragen Bekijk alle
Phone fell, no visible damage, doesn't turn on
My 920 fell onto a hard floor. There is absolutely no visible damage, and absolutely no sign of life. Something disconnected? Component destroyed?
If I can get it apart, is there any possible solution that I - not particularly gifted in these areas, but not stupid - can effect myself?
Is dit een goede vraag?
Score 7
10 opmerkingen
I have a Nokia Lumia 928 and I had dropped it that last time when I was moving to My new apt and it fell and u went almost 2-3 months without a phone and I finally got one n I need help to make it come back on this is really a small phone please help
. ~THANKS ~XOXOXO
door
hey that just happened to me i just threw the phone against the wall and it turned right back on. weird but it works.
door
Please read the comment below, don't throw your phone.
door
Please dont throw the phone... Just press the power and volume low key simultaneously for 30 secs...phone will definitely reboot...
door
Ok you have to on the button on your phone
door
5 commentaren meer tonen
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
kLyon, if you are absolutely sure that it is not coming on, you may need to take a look at the inside of it. Pay close attention to your battery contacts. Use this video guide to work on your phone. Of course, try a reset as explained on here and some more on here first. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
Thanks for your help! I found a comment on a forum about someone in the exact same situation as me - dropped phone, no visible damage, bricked. Even though nothing happened when it was plugged into power, he - as a last resort - put the phone on a wireless charger. In ten minutes it was fine.
So I tried the same thing: same result. Ten minutes and it was fine, back to normal.
Odd, huh?
door
I need help for my infinix hot note, it fell on hard ground and is not displaying any context
door
my itel A11 fell down on the rog and my flashlight was on when it fell but when i wanted to on my phone it did not on so i decided to remove the battery after removing the phone begin to vibrate so i removed the battery again after that it did not on again...pls what can i do
door
Het nuttigste antwoord
Press the power key and the down volume key simultaneously for 30 seconds. Its a hard powerboot and it turns on the phone. Just happened to me today and I remember doing it anytime my phone freezes.
Good luck,
FABJ.
Score 7
5 opmerkingen:
I am so very happy, my phone rebooted with this fix. So wonderful to have it working.
door
Thanks alot man, much appreciated. worked for me. Thanks again
door
Great Help Man. It worked for me.
door
Thanks man it worked
door
Does the phone have to be plugged to a charger
door
It is possible the LCD is damaged. Replacing the glass, digitizer and LCD as one complete unit ran me about $80. If you have ever worked on cell phones and have the proper tools, you can do it.
Score 1
4 opmerkingen:
The screen seems fine (visually). The phone just won't power up. If the screen was damaged, wouldn't the phone power up and just not display anything?
door
The phone could be powering up, but it is possible you can't tell because the LCD may be messed up.
door
Same here - if I charge, the display works fine to show me tha manufacturer and the % of battery, then dies again. The power button itself seems not working after fell. (Prestigio)
door
thank you so much !!! it worked for my phone.
door
my phone fell and refuse to on whats the problem
Voeg je antwoord toe
kLyon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 57
Altijd: 36,315
