Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
My vibrator and proximity sensor is not working
Hey
My friend gift me one iphone with broken display and proximity sensor, so i bought one from ebay and i assembled it, but the sensor is still not working.
Also i recently noticed my vibrator was not working and so i removed another from dad's iphone and used it but still nothing
im from italian, sorry for my english :)
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Cut two hole out of the electrical tape and place over the sensors
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
but it is weird because if i tap it with finger light should not pass
door
Look I'm giving you advise that is tryed and tested and works if you choose not to take that advise no problem
door
If you have changed the vibrate motor and it's still not working you need to change the volume , mute and headphone jack flex that's were the vibrate motor gets it's power from.. As for the proximity not working it's possible that to much light is getting in and causing the sensor not to work .. I simply use the electrical tape trick to fix this
door
what is that electrical tape trick ?
door
im not saying it is wrong :) i just want to be sure it is not anything else before disassembly the iphone again
door
If the proximity sensor still isn't working, you may need to replace the power button and sensor.
While you've got it open you may want to replace the vibrator with a brand new one. iFixit has them for only $9.95
iPhone 4 Vibrator Afbeelding
Handleiding
iPhone 4 Vibrator Replacement
Moeilijkheid:
Gemiddeld
20 - 40 minutes
iPhone 4 Power & Sensor Cable Afbeelding
Handleiding
iPhone 4 Power & Sensor Cable Replacement
Moeilijkheid:
Moeilijk
1 - 2 hours
1 Opmerking:
i already tryed one working vibrator but still not working
so about power sensor i need change cable? hm it looking hard this part
thank you for the rapid ansewer :)
door
Voeg je antwoord toe
Nikkolo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 199
