Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Possibly sleep/wake button problem. (Black screen)
Hi!
I have replaced the screen on a friends iPhone 4s.
The screen works fine at first when I turn it on, but after the screen goes black by itself or I push the sleep/wake button to make the phone sleep, it wont come back on.
(screen comes back on if I wait a while, but only once, then I have to wait some more)
I can see a little back light going on and of as I push the sleep/wake button, but nothing more.
I can turn it of without seeing and back on again and then it works fine until I push sleep/wake button or it times out and sleeps automatically.
Anyone had this?
Thank you!
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Sounds like a connection problem or faulty screen..
Open back up and make sure the connections are seeded correctly if so and the screen is doing the same then I would try the old screen and see if it happens to that..
Was dit antwoord nuttig?
4 opmerkingen:
Pretty sure its not connection problems. Why would it work fine after a restart evry time? :)
door
Just don't rule it out that's all I'm saying
door
I understand, thank's! :-)
door
No probs hope u get it sorted update us if you get it fixed thanks
door
Mine is doing this after being dropped, have tried restoring from a backup, and restoring as a new phone. I'm about to open it and check connections, will update with results.
1 Opmerking:
Yes! Opening it up and re-seating connections has done the trick. Now to duct-tape the phone to my body so I don't drop it again.
door
Voeg je antwoord toe
Fredrik zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 450
