Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Vragen Bekijk alle
Tabs on digitizer broke
Please help. I purchased two digitizers and have broken them both when pulling the cables over to fit. On the phone I'm repairing the tabs were much longer. What can I do to correct this,it's actually the digitizer cable that I've broke twice,
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi there this is the most important and tricky bit of the install just make sure when ur feeding the cables through not to pull them and the digitizer cable has a thicker end at the bottom of it once the start of that thick end is through the frame it will all slide in nicely
Was dit antwoord nuttig?
Score 1
just watch dome youtube videos. By the way you have to insert it in the slot while you rotate the screen.
Voeg je antwoord toe
Rod zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 64
