Ga door naar hoofdinhoud
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 Vragen Bekijk alle
Location of Hall Effect [Lid] Sensor
I have a late 2010 MacBook Air that has suddenly started sleeping every few seconds. I suspect a problem with the Hall Effect sensor falsely indicating the lid is closed. I could not find much information on the location. With some experimentation, it appears this is on the left side of the laptop, where the I/O board is located. Is the Hall Effect sensor part of the I/O board? In other words, is replacing the I/O board a likely solution?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Remove the I/O board, you'll see a small sensor on a stack of thickened PCB
Was dit antwoord nuttig?
Score 5
7 opmerkingen:
Thanks. To clarify: The short answer is, "yes." I found the sensor attached to the top-facing side of the I/O board, on a riser as Tom described. I was able to verify that powering-up the laptop with the I/O board removed did eliminate the sleep problem--but, of course, introduced an array of new problems. Unfortunately, cleaning and reattaching everything did not resolve the issue which returned with the I/O board reinstalled, But, I'm anticipating that a replacement will resolve the issue.
door
My replacement I/O board arrived yesterday, and did indeed resolve this problem. Thanks again.
door
Hi, i have the same problem with a1502 mac pro. The MacPro went to sleep randomly and waked up soon with open lid. Do you have any part number or picture of the up side of the logic or io board?
door
Here's the IFIXIT guide to replace the I/O board: MacBook Air 13" Late 2010 I/O Board Replacement. Often I find I need to replace the I/O cable as that sometimes gets damaged. As to a picture of the other side not much to see here: I/O logic bod from Mid 2011 model which is almost identical The Hall sensor is the square block just under the cable harness. I would try using a magnet placing it near the left side Tab key to see if it goes into sleep mode.
door
Thanks for your quick help. I think i can't solve this an simple part replace.
door
2 commentaren meer tonen
Voeg je antwoord toe
Kevin Barr zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 7,334
