Ga door naar hoofdinhoud
The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
166 Vragen Bekijk alle
I have a stripped case screw... how do I remove it?
I'm trying to follow the Vita 'replace the left joystick' guide and ran into a problem - I can't remove one of the screws on Step 1. I was able to remove the other 7 case screws, and even reach in to unplug the battery and touch screen cables, but...
... I'm worried that I can't just force it apart without damaging the right button board. What do I do?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Get a dollar-store eyeglass repair kit that contains those tiny screwdrivers. Select the best fitting one, and dip the point of the screwdriver into a drop of superglue (not so much that you end up gluing the damaged screw into the housing). Glue cheap screwdriver onto damaged screw, and when the glue has set, lefty-loosey and away you go.
Was dit antwoord nuttig?
Voeg je antwoord toe
rayhaven5618 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 3,542
