Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De GE Profile Tri-Temp is een vrijstaande waterdispenser met een geïntegreerd gekoeld compartiment.
Why is my cold water not cold?
My water cooler was working and all of a sudden the water is not cold. What do i do?
Is dit een goede vraag?
Score 12
12 opmerkingen
yes the unit is getting power
door Deel
yes the cold water lite is on but not the hot water lite
door Deel
So you get hot water but not cold - correct?
door Deel
Having same problem. Any answers?
door Deel
When i turn hot water switch on my cold gets warm near to hot why? If i new how to set temperature i would do that. Because my whole jug gets warm. Could be that im out of freon or low?
door Deel
7 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Check the plug & outlet and the fuse/breaker. Is the unit getting power?
If the unit is getting power then the compressor is not working correctly. It could be out of Freon or the compressor its self is shot. Which is why you aren't getting cold water.
If you are getting cold water not hot then the heater unit is burnt. In some units the waste heat from the compressor is used which can explain why you're not getting either hot or cold.
Was dit antwoord nuttig?
Score 13
10 opmerkingen:
Yes mine has hot water but the compressor not on very hot it is now unpluged
door Deel
And my cold water is hot I chrck fuse is ok and the breaker has power light on the on/off switch
door Deel
Please let me know where and how to get to the FUSE! Please
door Deel
Review this series of YouTubes: Troubleshooting a GE water dispenser and installing a GE heater element (part1). It will give you an idea on how your stand-alone unit works. Sadly, GE doesn't offer parts for this unit as they classify it as non-repairable.
door Deel
The hot water is working fine but the cold water is not cold and compressor is switching on and off by itself and I just bought it newly and I don’t know what to do. Kindly assist
door Deel
5 commentaren meer tonen
If you can hear the compressor running and it does not shut off, then the unit is low on Freon.
Score 3
6 opmerkingen:
how to fix fereon
door Deel
freon is a liquid inside the compressor used for cooling I think. But I'm not someone who has expertise in this type of repair.
door Deel
If motor feels hot disconnect the plug
door Deel
Where is the fuse??
door Deel
How do I add Freon to a unit
door Deel
1 commentaar meer tonen
Voeg je antwoord toe
felix quinones zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 110
Altijd: 94,780
