Ga door naar hoofdinhoud
Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
How to replace the digitizer?
I read the guide and watched a few youtube videos, but when I tried to replace a cracked iPod nano 7g digitizer I couldn't get the LCD out. I ended up breaking the thin metal frame around it and scratching it, as well as bending it. I successfully removed the digitizer. How do you get the entire display assembly out? Also, will an iOpener help me remove the small back piece (above bluetooth antenna), as I had trouble with this as well? Thank you.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
The iOpener should help. Make sure that the spudger is under the entire display assembly to prevent bending the metal midframe.
Was dit antwoord nuttig?
Voeg je antwoord toe
JT7 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 468
