Ga door naar hoofdinhoud
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 Vragen Bekijk alle
Replace full display assembly and palmrest
My MacBook Air 13 late 2010 has a faulty display, there is also a 6 inch crease on the aluminium bit so best to replace whole assembly.
Now I'm searching eBay for a1369 display but is there any other keywords I can use, surely Apple used this same display on other air models and not just the a1369
I also need to change the palmrest as it has the matching crease as the display. Now the guide here on ifixit does not specify about the keyboard, why not. Is it not easily separated from the palmrest.
You see I've seen a liquid damaged palmrest so if I can put my existing keyboard into it then obviously will be cheaper for me...
And same goes for palmrest, can i use anything other than a1369
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Do a search for Apple Part #: 661-5732, 661-6056.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Aidan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 127
