Display, flickering green lines
I have a mid 2009 17in MBP 2.8GHz.
The screen/display flickers with green symmetrical lines at random times. Its makes watching a video or gaming frustrating. They so up almost symmetrical around images.
I did find a temporary fix doing a google search.
If I apply pressure with my hand to the bottom of the laptop underneath the area of the left option key, it magically goes away. When I release the pressure it comes back.
Is there a permanent fix?
Is dit een goede vraag?
2 opmerkingen
I have exactly the same issue with the same MBP model. The green color is replacing the black tones onscreen but if I apply a little torsion on the bottom case the issue dissapears. I get a perfect image on external monitor (you check this). Removed the back panel and inspected video cable and socket, pushed on the logic board at many places with a spudger but issue stays on. I think it's a cold solder joint somewhere on the other side of the logic board. Did not tested it yet.
door lemerise Deel
I also have this issue. Has anyone found a fix?
door samecircle Deel
