Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Vraag afgerond
Restore problem on replacing battery
I replaced the battery in my 4s and then went to charge it it told me to connect to iTunes and when I did told me to do a restore and update whent through the process and then it has a error code of 21 and can't do the restore any suggestions?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Error 21 is a battery fault had it many many times before.
The battery you got is defective
Was dit antwoord nuttig?
Score 1
check the voltage of the battery in case it was flat?
I've found a guide about "how to restore iPhone 4s after iOS 8 update".
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 120
