Ga door naar hoofdinhoud
De iOpener is een geïsoleerde, warmtevasthoudende zak die je in de magnetron kunt verwarmen en waarmee je warmte kunt overbrengen naar de lijmlaag aan de rand van een iPad of een soortgelijk apparaat.
Hi, item does not get worm in 60sec
Hi,
It says that I have to heat up the iopener in 60sec but it does not get as warm as needed... I can almost hold it in my hand without it is to hot...
can I warm it in 2-3 min so that get useable?
My microwave works great...
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
I thought the same thing about 60 seconds not really warming it much so I put it in for 2 minutes and it did not go so well. Do not heat it for more than 60 seconds.
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
what happened?
door
Started smoking and slightly singed the microwave base. Also made me room and me stick of really badly burnt popcorn.
door
Had to throw the iOpener out as well because of the burned nature of the bag.
door
Only ever microwave the iOpener for 60 seconds at at time! If you find that the iOpener isn't quite warm enough after the first microwaving, go ahead and put it back in for another 30 seconds. It should be between 160F - 190F after that, and totally usable.
Score 2
2 opmerkingen:
Do you use an iOpener? I want to know because i was looking into getting one for repairs on iphones and other phones. Wanted to know how efficient the thing is!
door
For me it was more effective to use heatgun... so dont throw your money away...
door
Good old standered heat gun is the only job the I opener would never get it as warm as you need it
Score 1
You only need it warm
Voeg je antwoord toe
vk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 1,357
