Ga door naar hoofdinhoud
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
REPLACE BATTERY NOW condition
hi,
I was using my macbook without the AC cable, running by its battery which has no any draining issue before. After I got 4% battery, I connected the cable but it says REPLACE BATTERY NOW. as I said, the battery was perfect with its performance before this and I haven't any trouble before. When I disconnect the AC cable, it goes off.
My macbook like a new and I don't use it much because I have iMac.
What should I do please!
Is dit een goede vraag?
1 Opmerking
Did they end up replacing your battery at no expense to you? I would imagine they did. Please post a follow up. Thanks!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I could see an older model needing a new batt but a early '13 model shouldn't need it for at least 3 yrs.
Given the age of your system I would recommend going to Apple to have it repaired under Warranty ASAP as your time is running out (1 year without an extended Apple Care warranty).
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
abdullah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 506
