Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Vraag afgerond
iPhone 4S Blurry Rear Camera
Hello,
My iPhone 4S camera only focusses from really close, like 10cm, any further the photos get really blurry.
I did some research and found out many people solved the problem by hitting the phone at the back and front but that doesn't solve my problem. I also found out that the backpanel can be damaged with scratches, so I removed the backpanel and tried the camera without the backpanel. Didn't solve the problem. I'm considering replacing the camera and see if that solves the problem since I don't have warranty and don't want to pay ALOT for replacement or repair at the apple store.
My question is, should I try replacing the camera or wouldn't that fix the problem neither?
Thankyou.
Update
I replaced the camera and it fixed the problem! Thanks again!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Fitting a new camera is sure to fix the issue had this problem with customers in the past and a new camera sorted it..
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Allright, I'll replace the camera then, thanks!
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 2,542
