Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
Vraag afgerond
Signal loss after LCD swap iPhone 5
Has anyone experienced any loss of signal after replacing the LCD assembly? I just swapped mine out and now my phone will not go any higher than 3 signal bars..
I have done reboots & reset all network connections.
Just curious if there are any contacts I may have touched to caused this? Similar to iphone4's wifi & 3g.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Make sure you didn't touch the lower half of the logic board
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
I'm pretty certain I did not touch anything.. I was unable to put the metal plate that goes over the LCD connectors. I could not for the life of me get it screwed in without the lower cable popping out.
Hope that is not the cause..
door
Hook up the bracket from the left side.
door
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 148
