No Speaker Sound - Headphones Work Fine
Hi All,
The sound on my iPad all of a sudden stopped working. The sound works fine with headphones in and I can change the volume, but when I unplug the headphones I get absolutely no sound from the speaker, and I can't even change the volume.
I originally thought this must have been a software issue so I went through all the settings, checked mute etc.
After that, I tried a reset using the power and home button, and I even restored to factory settings.
I then changed the speaker with a new one, still no luck.
I have now changed the headphone jack as I thought this may have been interfering, but there is still no sound.
Any help would be very much appreciated!!!
Thanks,
Michael
Is dit een goede vraag?
119 opmerkingen
that exact thing has happened to me, did you find a solution?
door rkaypta
Clean the charging dock. It has dust in it or it is a little corrosion on it. Take a tooth pick and scrape it out a little bit. The iPad thinks it is connected to a speaker dock.
door Wilgus
I have that problem also I will try the toothpick thing
door Perry Robison
wow thank you Wilgus. it helped . i hope for long
door duskaz888
OMG!!! I've been sitting here an hour trying to fix this very problem. One toothpick and problem solved. Thanks a lot guys.
door dadrinomari
114 commentaren meer tonen
