Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Vragen Bekijk alle
Which cable controls touchscreen?
Just replaced digitizer, all went well, booted fine, but touchscreen not responding. Do you know which cable controls touchscreen?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
Ribbon #2. It can be kinda hard to get in place just right- make sure you hear it click.
Was dit antwoord nuttig?
Score 2
Ribbon cable 2 is the touch screen.
Score 1
and when i unglued the touch screen glass of touch screen ourselves ? What should I do ? when opened, can see perfectly bonded touchscren cable itself and not make contact with the touchscreen glass .What should I do ?
Score 1
I hope you purchased the right part, Apple in their infinite wisdom made the connectors slightly different from 3G to 3GS.
It could also be that you bought a faulty part, the failure rate from eBay is quite high because the parts are usually factory seconds,
Score 1
i don't know which i think it 2
Voeg je antwoord toe
Don K zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 20
Altijd: 12,366
