Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Vraag afgerond
Searching network, old sim, normal?
My iPhone 4s had a bad dock connector. I originally intended to fix it, but ended up just buying the iPhone 5s because it was released at the same time and I didn't have time to fix it. Today I replaced the dock connector following Ifixit's guide. The phone charges and works fine, but the bar indicator indicates that it is searching for a network. GPS and Wifi work. I do not have access to a micro SIM with service. The SIM is in the phone, however is disconnected. Is it normal for the phone to perpetually be in searching status if my SIM has been disconnected?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If you have a sim in the phone that is not active then it will stop searching and say not service, Check to make sure your iPhone has the correct date and time.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
The phone has the correct date and time. Looks like I need to look into this further.
door
I went in and set the time to be wrong, then turned automatic time setting on. Looks like that worked, it now shows no signal. Thanks! Now I just need to find a micro SIM I can use to test the phone with.
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 84
