Ga door naar hoofdinhoud
Lekker stuk fruit. Goede bron van kalium. Geel.
2 Vragen Bekijk alle
How To Teardown And Possible Poison?
This device is extremely treacherous! It has a given me many issues during tear-down for my son. First off hows a way to guarantee the initial snap at the top to begin tear-down and also what is this brown device at the bottom? Is it poison because my son refuses to ingest it.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
Learn from the Professionals! Observe a monkey. To open a banana: Ignore the handle-like stem. Turn your banana upside-down and focus on the nubby, pointed tip at the opposite end. Pinch this tip between your first finger and thumb — this will split the skin of the banana cleanly, allowing you to peel it back. https://www.youtube.com/watch?v=sf-yWxPm...
Was dit antwoord nuttig?
Score 3
Level up your SNAPBACK skill by wearing trendy sun visors while thumb wrestling with your friends.
Score 2
Snap from the bottom, you get better results every time. And yes the brown spots are poison. Avoid at all costs.
Score 2
If you split from the bottom it is easier to flick the deadly brown spot from the device before removing the protective covering
Score 2
Don't broke the white motherboard inside when you open it !
Score 1
Voeg je antwoord toe
Jay Kizzle zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 17
Altijd: 478
