Ga door naar hoofdinhoud
De Microsoft Surface RT (model 1516) is de eerste tablet die door Microsoft is uitgegeven. De tablet werkt op Windows RT, deze versie is speciaal ontworpen om te werken op een tablet. Om deze tablet te repareren heb je schroevendraaiers nodig, alsook gereedschap om hem te openen.
128 Vragen Bekijk alle
Dropped my Surface RT and now screen has some sort of greenish static?
My Surface RT was dropped by my little boy, screen didnt break, but once any white page is displayed on screen, the tablet shows like some green static after i start touching screen. With that said, do you think i need a new lcd assembly? Or might it be a loose ribbon cable on the daughterboard or anywhere internally? Screen works fine with dark colors and shows that static with bright colors.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I suspect the driver chips mounted on the LCD panel has become dislodged. Unless you have some visible damage to the case which could have cut the ribbon cable. I would suspect the display needing replacement. Then it gets into the question on how much will it cost to repair. Did you talk to Microsoft yet? I would.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
I do not have visible damage! So im guesing its just a chip dislodgement? Would that mean i can go into the surface and lodge it back in? because the screen works fine its just sometimes that it shows thegreen static
door
I have not talked to micosoft yet but sure will the lcd display for the surface runs about 179 on amazon but i think ill have a chat with microsoft support first see if they can give me a hint to fix it! Thank you for your anser dan
door
Voeg je antwoord toe
pelon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 1,845
