Ga door naar hoofdinhoud
Repair information for the iMac G4.
Blue screen of death
The hard drive won't boot up, but the startup utility does. Is all lost?
Is dit een goede vraag?
Score 1
2 opmerkingen
You sure you aren't trying to run Windows on it? :P
door
Good one. Recognize the "blue screen of death" as a MS term... but no.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If you can boot from the startup disk try running Disk Utilities to see if the drive can be repaired. Having a external drive plugged in to save your data wouldn't hurt either. If this doesn't work come back and we'll work on how to replace the drive.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
No repair it would appear. I can reformat but lose everything in the deal. I've been told we might firewire the iMac to our MacBook and see if the MacBook recognizes the iMac as an external hard drive. Haven't tried that yet. Thanks for the response!
door
I would definitely try the firewire target disk mode. I've found that it always works, provided the computer will boot to the point of recognizing the command.
door
Voeg je antwoord toe
Doug zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 2,875
