Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2376 Vragen Bekijk alle
Vraag afgerond
Why is my vibrator staying on after screen replacement?
I have just replaced the screen on an iPhone 4 and when I plug it in the vibrator stays on! I have replaced about 8-10 screens for friends but the only thing I have done differently this time is I damaged and had to replace the home button. Any suggestions on what I may have done wrong?
Is dit een goede vraag?
2 opmerkingen:
is this a 4 for gsm or cdma?
door
Hi, It's a gsm phone
door
Voeg een opmerking toe
2 Antwoorden
Have you tried:
Just Hold The Power/Lock Button And The Home Button At The Same Time For About 10 Seconds Until The Apple Logo Pops Up On Your iPhone's Screen
Just works as a reboot, not 100% sure it will work. If not its might be something internal that has changed.
Was dit antwoord nuttig?
1 Opmerking:
Hi I tried that but didn't seem to help. The battery is dead flat and when I plug it in the vibrator starts operating. Almost seems I have a crossed wire or similar. Not sure how?
door
make sure the dock connector is seated properly. be sure to check to see if there is any debri or corrosion.
Also try cleaning the connectors that touch the vibrating motor. make sure the screws are fastened all the way down and there is no corrosion.
Other than those two things there really isn't much you could've done to create this error. is it up to date on software?
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 79
