My ipad wont turn on
my ipad went flat over weekend now wont turn on
Is dit een goede vraag?
1. Verify that the charging cable that you are using works correctly. Try it on a different device.
2. Ensure that you are using the iPad wall adapter and a charging cable that is not more than 3 feet (1 meter) long. The longer cables have too much voltage drop to provide a proper charge.
3. Let it charge I disturbed for at least 10 minutes before you try to power it on.
If none of that resolves your issue, then you either have a bad battery or a damaged charging port.
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 196
