Ga door naar hoofdinhoud
Model A1320 / 8 or 16 GB capacity
155 Vragen Bekijk alle
My mom wash my iPod then dry ina dryer by accident
hi my i pod don't work anymore my mom wash because i left my i pod on my shorts then she dry in a dryer after she takes the cloth out of a dryer she fund my i pod and the i pod don't turn on an apple don't cover the i pod with the warranty on water damage you know what can i change o how to repair? thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
The only way is to disassemble the iPod.
then you need rubbing alcohol and a soft paintbrush, then clean the logicboard and the dock connector - but be careful - the parts are tiny. if everything is clean, let it dry and reassemble it.
try charge it with the wall charger - maybe you'r lucky and it will work again
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Make sure you leave it powered off for a few days before you plug it in, though.
door
Good! Now you can get a life! :-)
Score -1
1 Opmerking:
That's not a helpful answer... If someone else were to come along and look at this question, they would not find much of a solution in your answer.
door
Voeg je antwoord toe
luciano zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,376
