Ga door naar hoofdinhoud
Display second digit not working; some buttons not working
The second digit in the GE JES1384SF Microwave display is not working, so that 4:30 reads as 4: 0. The defrost and the cup buttons do not work. Otherwise, microwave works fine.
Is dit een goede vraag?
1 Opmerking
The microwave just needed to be unplugged and plugged back in. I didn't realize that, but we had a power failure and now it works fine again.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Main Control Board
If the microwave display is not working the main control board is most likely defective and will need to be replaced.
Display Board
If the display has gone out the display board might be defective. If the display goes out completely the problem can be either the display board or the main control board. If the display goes out partially the problem is usually the display board.
JES1384SF is a partial model number for a GE Microwave. To see specific parts for your Microwave, please add the last few figures.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
What about my buttons that also don’t work
door
Voeg je antwoord toe
TomND zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,590
