Ga door naar hoofdinhoud
De MacBook Pro is Apple's laptoplijn voor recreatief en professioneel gebruik. Deze reeks bevat onder andere de MacBook Pro 13, 15, 16 en 17-inch modellen met daarin weer verschillende modellen die gekenmerkt worden door hun respectievelijke Unibody, Retina-scherm en Touch Bar-ontwerpen.
20033 Vragen Bekijk alle
MBP A1278 locks up during bootup when upgrading from 10.6.3 to 10.6.8.
I have a Macbook Pro A1278 2.4GHz. While running OSX 10.6.3 the MacBook is perfect. My son got a hold of it and clicked on update. It installed 10.6.8, rebooted and now at the boot screen I get the Apple symbol and the loading circle. It then locks up and the MacBook is totally bricked. I have to open up the MacBook, remove the hard drive, format it, and then re-install 10.6.3. Apple is no help, to help they want a stupid amount of money for an issue with there OSX.
Is dit een goede vraag?
1 Opmerking
Can you give us the last three digits of your serial number so we can correctly identify your system.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
As you just did an update Vs a full version upgrade I'm very surprised your system is having problems. The only two things I can think of that could have messed you up is a firmware update that was also needed (the update was trying to install it). Did you get a message to wait while it updated the firmware? The second it your HD was in trouble ant it was just the act of updating that pushed it over (that has happened to me a few times on older systems).
I would recommend making a backup before doing OS updates or upgrades in this case its a little late.
Firmware:
At this point I would hold off taking the drive out. Instead start it up and let it run for about a 1/2 hour without touching it giving it time to update the firmware if you interrupted it it will try again.
If you did pull the HD you'll need to use an external bottle HD with the firmware update. Here's the Apple TN on getting the correct firmware EFI & SMC firmware updates for Intel-based Macs.
HD:
If the firmware didn't need updating > Do the above first <
  • Option 1 - Use an external drive to boot up your system and then try running Apples Disk Utility App to repair the permissions and then try repairing the HD. Did that fix it?
  • Option 2 - If you have a second Mac and can connect the two together via a FireWire or Ethernet cable back to back. Then restart your system in Disk Mode. Can you access your systems HD from the other system? If you can run Apples Disk Utility App to repair the permissions and then try repairing the HD. Did that fix it?
If you can't see the HD or you can't startup the OS off a second drive the drive is likely damaged to the point it can't be fixed. Time for a new HD. If you do decide on replacing the HD you do need to be careful with the SATA I/O speed. As we don't know the exact model you have we'll need to wait until you tell us so we can tell you what to watch out for here.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Woody zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 256
