Ga door naar hoofdinhoud
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Vragen Bekijk alle
New RAM install now Mac not restarting
Hi All
Pretty new to upgrading macs (was formerly a PC person) so I have a question regarding an upgrade I want to do on my Mac Aluminium Uni body. Currently running with the stock 2 gigabyte RAM but I wanted to bring it up with the 4 - so I bought a stick of 4 gigabyte (PC 3-8500) - which I believe is correct. So why is it when I install it, I just get a series of beeps (3 fast, than 3 slow) and nothing or a grey screen? I've tried holding Command, Option, P, and R and that doesn't do anything either (is it a timing thing? Do I do it after the grey screen appears?). I thought maybe I fried the logic board, but when I put the original ram back in everything boots up fine.
Am I missing something? Do I have to have BOTH slots filled in order for it to boot? Should I have gone with 2, 2 gigabyte instead of one 4?
I've searched the Google and the existing forums for this, but I can't find things that deal with what to do if you can't get the reset to work.
Is this just bad ram?
Please accept my apologies if this has been addressed and I haven't found the thread (in which case feel free to link it for me)
Current set-up:
Late 2008 Mac Book Uni Body 2.0 processor
no peripherals
2 gigabytes ram
160 g hard drive
What ever it had in the box, this is the first upgrade I've tried
Running on mavericks
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
If the system supports a max of 4GB and you have two slots then you cannot go beyond 2GB per slot.
Was dit antwoord nuttig?
2 opmerkingen:
Ok so I'd need 2 2 gig's instead of just one in the bottom slot.
Thanks for the info guys.
door
No problem and good luck.
door
Het nuttigste antwoord
RAM Type: PC3-8500 DDR3 Min. RAM Speed: 1066 MHz
Details: Supports 1066 MHz PC3-8500 DDR3 SDRAM.
Standard RAM: 2 GB Maximum RAM: 8 GB*
Details: 2 GB of RAM is installed as two 1 GB modules, no slots free.
*Apple officially supports a maximum of 4 GB of RAM. Originally, this model was only unofficially capable of stably supporting 6 GB of RAM, it is capable of supporting 8 GB of RAM if updated to Boot ROM Version MB51.007D.B03 and running MacOS X 10.6 "Snow Leopard" or higher.
Score 3
Voeg je antwoord toe
Kim zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 154
