Ga door naar hoofdinhoud
Een extern optisch station van Apple, in feite een rebranding van de MacBook Air SuperDrive.
Can it install windows 7 x32 bit on iMac
hello all,
i have an imac .i need to install windows 7 on my mac to play games but i can't install it because my internal superdrive is not working . when i make a partition and click install install windows 7 it restarts and a black screen appears and this shows up no bootable device press any key to continue
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi Joy. It seems to me that you have a few options here.
The first option would require replacing the internal optical drive. If that's the route you desire to take, we would first need to identify your iMac so that we may provide you with the appropriate replacement guide.
Your second option is to purchase an external USB optical drive, such as the Apple USB SuperDrive. This would allow you to boot the Windows 7 install disc.
The third option is to install Windows 7 from a USB flash drive.
I hope these options are of some help.
Was dit antwoord nuttig?
Score 1
Thank you very much for the information provided, you helped me a lot! I thought for a very long time how to deal with this and now I wonder what to do, maybe I can help someone here too? I can recommend very reliable guys at grademiners.com, you can see for yourself and do not waste your time anymore!
Voeg je antwoord toe
Joy Singh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 1,539
