iMac only 1 LED lights.
I have a 21.5 A1311 EMC:2428 iMac. I found it dead no power up, no fans. Tried PMC reset, remove replace Ram and checked power cable (good) and nothing worked. I got a new power supply (614-0445) from you put it all back together twice and nothing. Plugged it in and checked LEDs and I get 1 when plugged in but nothing changes when I press power button. Is this beyond my ability to fix? Could I have a bad power button? Is there a decent write up on how to start without using power button for my specific model? Any help would be greatly appreciated.
Is dit een goede vraag?
4 opmerkingen
That is what I thought. Thank you for the quick response. I'll try the apple route first to get a quote and if it's unreasonible I will try ebay. If I only would have paid the extra money for apple care. Lesson learned!
door bcageprotection
Warrantees - some swear buy them, others swear at them. Complicated expensive machines (Cars, Computers, TVs) are probably worth covering with an at point of purchase extended warranty. Other things (tools) ought to be built to last. It's like keeping a current backup. Though everyone knows and has been told -only those who have been burned really understand and follow through with the practice.
door originalmachead
Yeah foresight is a B@$&h!!! I'll bet if I had gotten the warranty it would have broken a year after that! Lol.
bcageprotection.....this sounds spookily like what i am seeing now. Do you remember which LED was lit up before you replaced the logic board?
I bought a imac with a known power issue.....thinking i could save her! I was seeing led #4 lit up when i plug in the power cable. When i push the power button, the light goes out and stays out.
I was advised by someone on another mac site to try some resets including removing the coin battery. After that activity, i now only see LED #4 light up for a moment and then go out. Power button has no effect. If I plug and unplug the power cord from the wall, no change. If Iphysically remove the power cord from the IMAC, I again can see the LED #4 briefly light up.
Trying to determine my next step.....My 2011 IMAC 21.5 is dead as a door nail!
door Paul Singer
