Ga door naar hoofdinhoud
PowerBook G4 Aluminum laptops with 12-inch displays. Released in 2003 from Apple.
12" PowerBook Dual Drive, is it possible?
Is it possible to replace the existing optical drive with a dual drive? Is there any for this generation? If yes, can it be a S-ATA HDD or SSHD in that drive?
thanks
Update
Good news. Could you suggest something on eBay or Amazon, please?
Thanks.
Is dit een goede vraag?
Score -1
1 Opmerking
This question was migrated from http://meta.ifixit.com/Answers.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Yes, this is possible, using a 12.7mm optical drive hard drive adapter, but it must be IDE. iFixit no longer sells the part, and it may be hard to find on Amazon today.
However, any hard drive installed will be bottlenecked, which cannot be avoided. This is a limitation of the IDE bus being capped out at 100 (IDE) or 133MB/s (EIDE). Buy a cheap drive or live with this bottleneck, but it won’t hurt anything.
As far as a guide is concerned, I don't know which CPU you have so I can’t find one. You will need to find the guide on your own, unless you can provide the CPU speed for your machine.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Would there be any issue with BUS speed?
door
Voeg je antwoord toe
Sorin Paliga zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 143
