Ga door naar hoofdinhoud
Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
How can I find an Eee 1005HA compatible screen?
I ordered a replacement monitor from a reputable vendor for our cracked Asus Eee 1005HA, but when I received the order, the two screen connections, where the wiring plugs in, didn't match (pic here).
I contacted Asus, which provided me the following information on the screen:
LCD TFT 10.1' WSVGA GLARE (A+)
Part number:
18G241010402Q
But I can't find replacements for that part number mentioned anywhere on the Internet!
Can I jerry-rig a connector for the monitor I already bought? They appear to have the same number of pins. The new, incompatible screen seller offer to exchange or refund it, which I'm happy to do if it doesn't work, but I really want to get this fixed.
Is dit een goede vraag?
Score 1
1 Opmerking
It was nice of Asus to give you part information!
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
finding an lcd should not be the problem - ebay helps
but since you've already got the wrong one, try to search for the lcd with the info's you got on the original screen's backside.
the asus part number won't help much - try to google it ;-)
search for us sellers and simply ask them about the connector
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
You need an HANNSTAR HSD100IFW1 panel.
I had the exact same problem - ordered a replacement LCD, and got the same type you got. Wasn't too happy about it because the eBay vendor stated it was for the 1005HA.
Luckily enough, I ran across this page where they explain the exact panel needed for the 1005HA.
Hope this helps. The Hannstar panels are found on eBay, but my problem is that the vendors show the panel back without the foil cover, and I'm not sure if I need to move the foil over or what. I'll find out soon enough. :)
Score 2
1 Opmerking:
Thanks! Would you mind updating when you get a chance to confirm it works? The netbook is still sitting, screenless and sad.
Thanks for updating here!
door
hi! it is 10inch screen, WSVGA (1024x600), Matte, you can buy from http://www.laptopwide.com/asus-eee-pc-10...
1 Opmerking:
HANNSTAR HSD100IFW1
available from Amazon
door
Voeg je antwoord toe
Michael Morisy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 5,830
