Ga door naar hoofdinhoud
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
SUD and F35 Error
My Kenmore Elite HE3 washer continuously getting SUD error when I start the washer, after clearing SUD error couple of times I am getting F35 error.
Please give some helpful suggestions for fixing this.
Is dit een goede vraag?
Score 1
1 Opmerking:
I also get the SUD but no other error code. Does anyone know what that means??? Thanks!
door
Voeg een opmerking toe
1 Antwoord
I am not positive this helped but I have done several loads of washing since I did this fix and have had no problems so far. Hope this worked.
The fix I did was to remove the bottom panel, 3 screws.
Removed the cleanout from the drain pump.
This had some lent and black muck in it.
The plug removed also comes apart. Two pieces just snap together.
I was able to completely clean it all out.
Hope this helps, and will be the fix.
Update
The sud code means there is excess suds in the machine.
It may be due to the drain pump needs to be cleaned.
Was dit antwoord nuttig?
Voeg je antwoord toe
Thomas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,182
