Ga door naar hoofdinhoud
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 Vragen Bekijk alle
Is there any differance between 2415 and 2560 lcd
My ıpad 2 (2560) lcd was broken.I changed the LCD, but I did not take any display on the screen except horizantal color lines.
Is there any differance between 2415 and 2560 LCD panels.May be I used to wrong one.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It's more likely that you didn't seat the cable correctly. Try reseating it. DON'T close up the screen until you test it and it works, as taking it apart is difficult and the more you do it the greater a chance that it will break.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
cem kutlu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 463
