Ga door naar hoofdinhoud
First-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
130 Vragen Bekijk alle
How do I get out of connect to iTunes you
My iPad is stuck in a connect to iTunes loop. It has a error code 28. I have search the web for a week and cannot find a solution that works. I have even tried to jailbreak it and it still will not bring it out of the loop. Need some professional advice if you would please help. Thanks Rawpitbull
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
what had been done to it previously? its either a software lockout, done by the OS or an iCloud account if you are running iOS7 or later, or its a hardware fault... it depends on what the symptoms were beforehand though
Was dit antwoord nuttig?
Score 1
I have never had an iPad, but I would probably back up all my data into iCloud: then I would reset the iPad. See this video:
https://www.youtube.com/watch?v=m_ESKiCF...
Voeg je antwoord toe
Rawpitbull zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 210
