Ga door naar hoofdinhoud
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
150 Vragen Bekijk alle
Changed LCD and Digitezer, now dipslay is black
Please help with this:
My Nexus cracked and the digitizer didn't work.
So I got a new LCD&Digitizer, replaced as per instructions - now Touch screen is OK, I can click and hear beep. The display however stays black. Sometimes I can see in the very dark something on it (the hour for example). Most of the time I see nothing.
Can you suggest what is wrong?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Try reconnecting the LCD cable, if not return the screen.
Good Luck!
Was dit antwoord nuttig?
Score 1
Try turning the device off - then back on. That's generally the problem on other devices.
It sounds like your backlight isn't working. A simple restart will hopefully fix that.
Score 1
I am having the same problem. Black screen after replacing broken screen and digitizer
I have found the solution. Change the lcd / video cable and it will be all fine then. Just did it today and it worked.
http://www.ebay.co.uk/itm/281198840636?s...
Voeg je antwoord toe
Peppi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 285
