Ga door naar hoofdinhoud
Repair guides and support for small electric personal space heaters.
Why is my eden pure blowing barely warm air?
I have a eden pure 1000xl heater. It is blowing out air and working well but the air is only about 75 degrees.
I can see the light is on but it is not very bright in comparison to my other eden pure heater. Is this a bulb issue? I am extremely handy but before opening the box I am looking for knowledge. The unit was manufactured in 0907.
Is dit een goede vraag?
Score 5
2 opmerkingen
How to know if bulb is bad
door
My eden pure was only blowing cold air...so i bought all new tubes and put in it but it's still only blowing sorta warm air? I don't know what to do please help!
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
The element is most likely burnt out. Here's a video on repairing it: http://www.youtube.com/watch?v=tSTHbLrUp...
Was dit antwoord nuttig?
Score 2
If your EdenPURE 1000 XL is only blowing warm air, that is certainly a sign that one or more heating element bulbs need replacing. You can watch a video on this page that provides a step by step guide on replacement the heating elements in your heater. It’s very well done and the individual who provides the demonstration is an authorized edenpure parts dealer.
Score 2
3 opmerkingen:
Not only is it blowing warm air, but the fan speed is slower than usual as well. Is this still a heating element issue?
door
I have the same issue as Robert S. How can I fix this?
door
My blows cold air on one side and warm on the other side is that the way it should work or not
door
My Edenpure is making a high pitched whistling sound and after about 20 minutes, it cuts off. One time it kicked a breaker. What's up? What should I do?
1 Opmerking:
If you're edenng pure heater is making a high-pitched whistling noise after about 20 minutes it sounds like the bearings on the fan are out, causing the motor to trip the breaker. Replace the fan.
door
Voeg je antwoord toe
mike zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 41
Altijd: 37,453
