Ga door naar hoofdinhoud
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
56 Vragen Bekijk alle
Vraag afgerond
USB Connector Cable torn down
Hey guys,
I have made a disply replacement on my Lumia 920. Thanks for the tutorial. It works!
Unfortunately I torn down the USB Cable at the begin of the disassembly. I bought a new one. The same problem with the new one. In the moment when I am closing the case the cable is squeezed and then its torn down.
Is it possible to make a soldering or to use any glue?
Best regards
David
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi,
You can not use soldering option here unless you are willing to risk your device for soldering however you have to buy a new usb cable and connect it if you think you can not achieve that percision then take it to a local repair shop for fitting the case after plugging usb cable. Try to keep a steady hand while fitting if you give it a retry.
Good luck.
Was dit antwoord nuttig?
1 Opmerking:
Hi,
thanks for your quick reply. OK I will try it a third time with a new usb cable. Hope not to squeeze the connector.
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 395
