Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Lost battery connector screw 1.5 um
I replaced my dying battery on my Iphone 4S. All I had to do was replace the screws that hold battery plate down. I lost the screw that holds the grounding clip. Where can I find a replacement screw? The length of the screw is 1.5 um.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
i went on amazon and because i had the same problem i overnighted an entire screw set for ten dollars with prime if you have time you can get them for 2 dollars and then youll have screws for other electronics but you can also go to a hobby shop especially an rc car hobby store and they should have them. here's the set i bought came with a nice bag and all the parts
http://www.amazon.com/gp/product/B0094OE...
heres a list of them
http://www.amazon.com/s/ref=nb_sb_noss?u...
hope you've already found some if not hope this helps
Was dit antwoord nuttig?
Did u manage to fix this when you bought the screw?
Voeg je antwoord toe
Jim zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 966
