Ga door naar hoofdinhoud
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
150 Vragen Bekijk alle
Vraag afgerond
Wifi Antena broke off
Hello,
While trying to repair a problem with my nexus accidentally i broke off one of the wifi antenna, now my device signal wont go higher than half, is there anything i can do such as repair or replace the antenna ?
Thanks in advance.
BR
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi Angel,
Do you mean the gold prong on the motherboard, there are two of them, if so you can find these on any scrap laptop motherboard, just solder one off, clean the pad on the nexus mobo and re-solder, i use solder paste as you dont need so much heat to do the job, if you dont have access to a scrap mobo then you can use the spring out of a ball point pen but its a bit tricky, also you can solder a piece of wire from the pad on the mobo to the pad inside the lid which i have not attempted but sound workable, just get the correct pad inside the lid.
Cheers
Mike
You owe your existence to Tinkering cavemen
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 2,721
