Water Damage: Replaced Top Case. Power Button Not Working, Now What?
I have a MacBook Pro 13” Mid 2010 that sustained water damage. I cleaned the board and replaced the top case as recommended in the post to my original problem. The top case came with the speakers, subwoofer, and the trackpad.
The MBP works now EXCEPT (you all knew this was coming) for the power button and the subwoofer.
What I did: I checked the ribbon cable and it seems fine. Just to double check, I disconnected and reconnected it. I also tried to reset the SMC per suggestions in ifixit.com posts. I followed the instructions here
I did the above procedures twice.
Still no luck. I can’t use the power button to turn the MBP off or on. I keep having to jump start it. I hope this is not a permanent thing.
This is my system info:
Model Name: MacBook Pro Model Identifier: MacBookPro7,1
Processor Name: Intel Core 2 Duo Processor Speed: 2.4 GHz
Number of Processors: 1 Total Number of Cores: 2
L2 Cache: 3 MB Memory: 4 GB
Bus Speed: 1.07 GHz Boot ROM Version: MBP71.0039.B0E
SMC Version (system): 1.62f7
What else can I try?
Thanks in advance for all the great help so far.
Update
I contacted the seller and am returning the top case for a full refund. I have located another replacement for it for the same price as the first one I bought that includes a two year warranty from square trade. Will keep you all posted.
Is dit een goede vraag?
Where did the replacement part come from? You should be talking with that vendor (was it new or used/like new)?
door originalmachead
Machead, I bought on eBay. Here is product description:
This auction is for: Apple Macbook Pro Unibody A1278 13.3" Mid 2009-2010 Genuine Top Case/Palmrest with Trackpad & Backlit Keyboard. Includes LVDS and iSight brackets, & center keyboard bracket.
Apple Part Numbers: 661-5233, 661-5561, 661-5858, 661-5857 Interchangeable.
Fits: All Macbook Pro unibody 13" Mid 2009 to Mid 2010 (all non Core-i Series). HAS SD CARD SLOT ON LEFT, NOT FOR EXPRESS CARD (pre Mid-2009).
Assembly is pre-owned in excellent working and cosmetic condition, palmrest is excellent, almost zero marks or scratches, aluminum is very clean and bright. Keyboard has almost zero shine, all lettering is clear, bright, and sharp. Trackpad is flawless. Assembly overall is in EXCELLENT shape, very well taken care of!!
30 day warranty, Money Back guaranteed.
I just wanted to make sure I didn’t miss anything. Please advise. Thanks!
door DSCantu
