Ga door naar hoofdinhoud
De MacBook Pro is Apple's laptoplijn voor recreatief en professioneel gebruik. Deze reeks bevat onder andere de MacBook Pro 13, 15, 16 en 17-inch modellen met daarin weer verschillende modellen die gekenmerkt worden door hun respectievelijke Unibody, Retina-scherm en Touch Bar-ontwerpen.
20003 Vragen Bekijk alle
MacBook Pro will *only* run with disconnected battery
Ok, so, my friend spilled a scotch and soda on his mid-2009 Macbook Pro, and I'm trying to suss out the extent of the damage.
The computer will boot and run normally off of AC power with the battery disconnected. With both the battery and AC adapter connected, however, the it will shut down halfway through the startup sequence (after the chime, but before the grey Apple logo.) Furthermore, if I reconnect the battery while the machine is up and running, it will shut off immediately.
(Also, the battery test button does nothing, no matter what is connected or not.)
So the question I'm left with is whether it's the logic board's battery-in port that's problem, or if it's just a bad battery. Obviously, the ideal next step would be to see if the machine starts up with a known-good battery in place, but I unfortunately do not have one to try it out with, and I'd rather not spend the money to buy one, only to find out that it's useless because the MBP's logic board is faulty.
What do you think the likelihood is that it's only a faulty battery causing the shut-downs? Is it worth risking the $150 to find out? Or is it pretty much certain that the logic board is bad?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Some of these laptops will not boot with a bad (-25% charged) battery. But will boot and run slow off the charger only. Examine the logic board around the battery connector under a magnifier for corrosion or burnt/swollen components.
At that age a new battery would be appropriate. I guess you'll have to price out the cost of fixing the port/logic board vs just a battery.
If the new battery isn't the fix you can part out the machine and the new battery to recover some $ for a new(er) laptop.
If this answer is acceptable please remember to return and mark it.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Jaime zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 4,484
