Ga door naar hoofdinhoud
The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
465 Vragen Bekijk alle
Broken onboard USB ports - where to source replacement?
Anyone know where to get a replacement on onboard USB port unit found on a PS3 Slim CECH-3003A?
These two have been destroyed by kids and one is totally missing the internal "blade".
Trawling the web hasn't found me a supplier anywhere except for a questionable 2nd hand one in the USA on Ebay.
Anyone maybe tried replacing them with some standard USB sockets?
I'm based in the UK so something in europe would be better.
Any pointers appreciated!
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I just replaced the connector with a set of standard PCB USB A female ports.
The only hitch was that I bent two side posts over, soldered them together ad anchored them to the middle post hole for strength.
Works great, it even lines up with the existing holes.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
I need someone replace my Ps3 slim USB port. Please
door
I would find a electronics parts store in your area and ask them for a recommendation.
Example: I got the USB ports in the photo from "Vetco Electronics", they had business cards from many hobbyists who were willing to work on a PS3.
door
FYI: I used this sort of ports similar to the ones in the below link and they are still fine after more than a year of use. If you don't open the case you can't tell that it isn't the OEM part.
http://www.amazon.com/uxcell-Female-4-Pi...
door
hi there, make a tutorial?
door
Just solder a USB extension cable on
3 opmerkingen:
That would be what you call a total bodge up!
door
At least it works. Although it looks funny. Try to find anyone that sells scrap boards on ebay,you may get one with a good USB ports
door
This does indeed seem to be the only solution, but even a dead ps3 slim sells on eBay for more than I'd expect to pay for a socket on its own.
I might just have to fix it up so only one port works, then the guy can use one of the many USB hubs available for it.
door
Voeg je antwoord toe
LosBenitos zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 48
Altijd: 8,492
