Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
sim reader is screwed
hi
i just encountered this site and u guys are doing a fabulous job.
i have an issue with my iphone from past 3 months.
i did not used it because i dont know how to fix the p[roblem.
the problem is that one of the strings in the sim reader is displaced from its actual position. when i insert sim tray the bottom part is broken and was struck in there. i can see the metalic part of the reader through the vent.
i think replacing sim tray will resolve the issue but i cant find a tutorial to replace it.
i really appreciate if some one could post a tutorial for fixing this.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
well, have a look at the teardown - it should help.
at http://s1.guide-images.ifixit.com/igi/ZC... you see the mainboard with the sim holder - should be fixable if the original contacts are still ok, but you my not be able to remove the sim card depending on your fix.
Was dit antwoord nuttig?
Score 2
The sim card does not activate when I put the sim card in the phone. I have replaced the tray with a new one but it still does not read it? Can you help me?
Otis Hughes
812-655-1881
1 Opmerking:
My note 2 is doing same thing n it was working just fine, then i switched sim cards n now it wont read sim, help plzzz if u know how??
door
Voeg je antwoord toe
umesh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 2,936
